Weirdboy - 40mm base ?
14 replies to this topic
Keithandor
Keithandor
  • 15 posts
  • Army Name:Da Pale Orks
Zark the Damned
Zark the Damned
  • 232 posts
  • Army Name:Waargh Kargrak
The current one yes.
Old ones it depends on your personal preference, use the one it came on or a bigger one. My old RT weirdboy uses a standard 25 but the warphead is on 40.
greggles
greggles
    Warbuggy Driver
  • 1,544 posts
  • Army Name:Trust in Rust
I moved all non character orks to 32mm, and all 3W or higher character orks to 40mm.  Looks great and they actually fit on the bases for once.  Note this will give you a slight disadvantage in tournament play, which is why no one cares if you do it.
  • 1,327 posts
You rebased all of your models to the 32mm?!?  You crazy!
I can't do that.  It makes sense for some models that are legendary for their base overhang like Nobz and lootas though.
StormGuard
StormGuard
  • 106 posts
After re-basing all my heresy era Ultra-Beakies, and my 40k Space Wolves, I don't think that My mental state would survive upgrading all my Orks to 32mm bases.
Although I do plan on re-basing my Ork Storm-Boyz to 32mm, as they will be more stable on the larger size base.
Onwards and Upwards.
SG.
Demo Charges 101:  Pull Pin, Throw, Run Away Very Fast.
greggles
greggles
    Warbuggy Driver
  • 1,544 posts
Yup Philly.  I rebased them all!
https://imgur.com/a/idfer
32mm on the boyz, 25mm on the grots, 40mm on the characters.
  • teister likes this
Bellygrub
Bellygrub
  • 620 posts
  • Army Name:Bloodtoofs Badmoon Raiders
 I left the boyz on 25's (I have way to many) but I did rebase all the unit nobs to 32's. Actually I put all nobs on 32's and all characters on 40's (or bigger larger).
  • det likes this
Keithandor
Keithandor
  • 15 posts
Ok thanks guys
Here are my new Weirdboyz :)
32mm bases at the moment , I will change them to 40mm.
78B3F5A5-3685-4924-BB0D-C8650B311C39_zps
  • Itinerate Ork, Orkimedez and greggles like this
det
det
    Phobiak
  • 2,221 posts
  • Army Name:Snake Korps
Damn, methink I'll do the same!!! ;)
modelling: my completely completed stuff
gaming: 1850 mech blood axes list updated
fluff: what being blood axes is all about
looting other races: tautechmarines (other site thread)
  • 1,327 posts
You people are crazy. Once a model is done, it's done. I'm not hauling them off their bases and redoing 300 painted orks.
  • teister and Garslag like this
greggles
greggles
    Warbuggy Driver
  • 1,544 posts
I was redoing mine Philly, so it was an easy decision for me.  (I sold/gave away my old boyz, and started the mob from scratch).
det
det
    Phobiak
  • 2,221 posts
Actually I found some pretty good base extenders which work wonders...no need to strip the models off the base and with the "pebbly" base I use it's just easy to cover the (actually mostly non-existent) cracks.
I'm not rebasing all of my orks, and I must say sometimes keeping on with the old basing method is sad since my skills have improved a bit, but in the end the complete result is good enough for me so yeah, it's just the way it is.
Maybe my beakie army will be rebase since it never actually was painted...we'll see...as I have already too many projects going on.
Boss Ardnutz
Boss Ardnutz
  • 620 posts
  • Army Name:da Maniakz
Det, which base extenders did you get?
det
det
    Phobiak
  • 2,221 posts
so sorry, saw this only now!
these ones:
http://taleofpainter...-32mm-base.html
they fit perfectly as long as you didn't colour the base ring too much (I did on some models...argh!)
Boss Ardnutz
Boss Ardnutz
  • 620 posts
Thanks det!
