KFF
69 replies to this topic
laughterofgods
laughterofgods
    Warbike Boy
  • 1,500 posts
I am wondering how people are interpreting the KFF.  The rules say that "units that are entirely within 9" have a 5+ invulnerable save."
Coming from both 40k in past editions and war machine I interpret this to mean every model must be within 9", but all of every model does not need to be within 9".  Weapons can only shoot models within their maximum range, but we don't require the target model to be completely within that maximum range.  You only need to touch it.
skarnir
skarnir
  • 717 posts
  • Army Name:WAAARGH SKARNIR
The one game I have played this edition. I counte the models that were within 9" as being in cover.
I dont see the need for thr entire base being within 9".
We dont measure movement or range to target to the furthest ppint from origin.
I dont see why we would have to do it for the kff. Its not a cover save.
May the Enemies blood on your choppa never dry or your welding torch grow cold!
Ork Tactics by Laughterofthegods
https://www.dropbox....actica.pdf?dl=0
http://www.the-waaagh.com/forums/index.php?showtopic=50985
  • 1,327 posts
I had never really though of that.  I would assume the entire model needs to be within the 9" bubble myself, though now that I think about it, nothing else requires that all of a model's base be in that space.  Similarly, when it refers to auras, most people just have part of a model's base in the 6" range and count it.
Choppanob
Choppanob
    Squigpipes
  • 67 posts
  • Army Name:Still working on that one
This is stated in the FAQ of the Warhammer 40,000 Rulebook
Q. Can you clarify what the difference is between ‘wholly within’
and ‘within’ for rules purposes?
A. If a rule says it affects units/models that are ‘wholly
within’ then it only applies if the entire unit/model is
within. If it just says ‘within’, however, then it applies so
long as any part of the unit/model is within.
For example, units gain the benefit of cover if every
model in the unit is either on or within terrain. So long
as all the models in that unit are either on or partially
within the terrain, they gain the benefit of cover.
KFF has a bit of a different wording "entirely within" instead of "wholly within" but it's the same really, so all of the model base needs to be inside the KFF bubble. (i miss the old way)
  • Snarknit Grokguzz and StormGuard like this
:yes Live off the land. :search Go to find war. :dakka Kill wot comes close. :thumbs Da old ways are best.
Snarknit Grokguzz
Snarknit Grokguzz
  • 340 posts
yeah, I'd go with a similar interpretation/reading of that for the KFF - there is no grammatical difference between "entirely" or "wholly" in this context.
Boss Ardnutz
Boss Ardnutz
  • 620 posts
  • Army Name:da Maniakz
The example in the FAQ looks to me like an example of "wholly within", so KFF would only need part of every base to be within 9".
  • 1,301 posts
At this point I'm ok with playing it ether way. the explanations that I've read leave me unsure. I was in the every model must physically be inside the 9" area but it was pointed out that it's the units that has to be with in the area. so some parts of some of the model bases could be "touching".  I guess it's an issue with the language they used. More consistency next time?
laughterofgods
laughterofgods
    Warbike Boy
  • 1,500 posts
Now maybe I am being too anal retentive and drawing on warmachine too much, but it says that the unit needs to be entirely within.  This would seem to say that every model needs to be within.  Instead of saying every model in the unit needs to be entirely within.
Choppanob
Choppanob
    Squigpipes
  • 67 posts
So you mean that this way you could put some (solo)models with big bases/footprint like dreads, Gorkanauts, battlewagons etc, just a bit into the KFF bubble and still give them the save?
i know it used to work that way when i played way back, and that you could exploit it with only having 1 boy in the unit inside the KFF.
But GW changed that now for the boyz atleast, so vehicles and such would still work like the old days then?
It would at least give some more flexibility for the bigger models/units
  • 1,301 posts
We really ought to ask GW.
We need to phrase the question so we get a proppa answer.
Snarknit Grokguzz
Snarknit Grokguzz
  • 340 posts
I'd err on the side of the "safer" bet - in this case, every model must be entirely within the bounds of the area effect in order for the unit to receive the benefit.
StormGuard
StormGuard
  • 106 posts
I 100% agree, I would advise erring on the safe side as well, for now anyway. :yes
SG.
Demo Charges 101:  Pull Pin, Throw, Run Away Very Fast.
  • 1,301 posts
The KFF has loads of room under it now. Id recommend, any models not "under the bubble" be in the back some where, they can die first.
  • 2,146 posts
Can't help thinking that it should have said 'models that are entirely within 9" have....'
As written it implies that a unit could have one model in base contact with the KFF mek but if only one model is even partially outside the bubble then none of the unit get the save :?
Greyhound
Greyhound
  • 419 posts
  • Army Name:Greyhound's Horde
That's exactly what it means. If you can fit 29 models under it but one does not fit, no one in the unit gets the benefit.
  • Snarknit Grokguzz likes this
Snarknit Grokguzz
Snarknit Grokguzz
  • 340 posts
Yeah, that's my reading as well.  I don't *like* the rule, but that's how I understand it. It's like GW's trying to eliminate area effect spam, but then, why not just remove those elements from the game entirely, rather than have them but only under such extreme restrictions?
Boss Ardnutz
Boss Ardnutz
  • 620 posts
It is a rather ambiguous rule. Does "entirely/wholly" refer to the unit, the individual models that make up the unit, or both? What about units that consist of a single model?
The FAQ makes it even less clear, especially blurring the line between units of many models and units of one model.
It looks to me as though the intention is to have the KFF behave like cover from terrain. For multi-model units you get the bonus if every model in the unit is at least partially overlapping the terrain, but you lose the benefit as soon as a single model is completely outside the terrain. For single-model units, you could either get the benefit only if every part of the model is within the terrain, or if any part of the model is within the terrain - that is not clear to me either before or after the FAQ.
Greyhound
Greyhound
  • 419 posts
Absolutely. Put the first wound on the model outside the KFF, let him die, then "swoosh" the unit is covered for all other wounds.
Choppanob
Choppanob
    Squigpipes
  • 67 posts
It seems that cover and KFF needs the units to be entirely within, and since they are using cover as an example i have a feeling the KFF is working as the cover rule.
So units with muliple models gain the benefit of cover if every model in the unit is either on or within terrain.
So long as all the models in that unit are either on or partially within the terrain, they gain the benefit of cover.
The same for single models/characters, but maybe a vehicle like kans,dreads, nauts, battlewagon and the like needs to be at least 50% inside the bubble to gain the benefit?
Otherwise is seems to me that you still can make the bubble artificially bigger bij putting those models just a bit inside the bubble.
But it seems to me that GW just wants to get a away from that.
One of the reasons besides that units needs to be entirely within, is that the embarked KFF only gives the transport the save instead of creating a bubble centered around the hull.
You could cover the most part of your advancing army with 1 Big Mek with KFF inside a Battlewagon + putting models slightly inside the bubble or one boy to give the entire unit the benefit. (a bit Op really)
  • 1,327 posts
I really think the intention is to have the entire model inside that 9" radius.
Morkanaut gives you a massive bubble.
