Ork compatible/enhanced terrain
- - - - - terrain
25 replies to this topic
  • 479 posts
Placeholder for latest pictures.
  • 479 posts
Not sure if this topic really belongs here. I am working on terrain meant to be usable as Middle Eastern and/or North African. But, I plan to make Ork-flavored gubbins for the buildings, various add-ons, details, and other non-permanent enhancements.
To get started, I divided my best terrain, that is done or close. Durability and closeness to tabletop completion were also key factors to consider. I plan to get all four tables worth of terrain to a playable level, then start enhancing each with extras that improve the visual appeal. My current group only plays painted, and most bring extremely nice armies to play. At first these tables will not be as nice as the armies on them, but I plan to keep upgrading components till the table starts to look fantastic.
In terms of restrictions, each table worth of terrain needs to fit inside a 20 gallon flip top container, hopefully with enough variation that many interesting arrangements can be made. The plan is for 20-30% of the components in the bin to NOT be used in any given game. If possible, I will later make double sided table coverings, or include two different ones, to provide even more variation. Each table is named, so it is easy to select the right bin when going to play, and to have a theme to work with.
Some of the pieces in the pictures below have been changed already, and I will have updated pics as I make progress upgrading these tables. For example, the tire walls are distributed between all the tables (and I may need to get more.)
Palm Desert
Industrial Complex
Desert Mission
Desert Village
  • Zagursnik likes this
  • 479 posts
I plan to make pallets with various items on them. One use is to put them in the back of my trukks, but also to use next to buildings to increase visual appeal. I have not yet laser cut the pallets, but I have base coated a bunch of wood storage drums, which will need washes, writing, decals, etc.
I have two types of drums. The larger ones are almost unusable and came from a asian dollar store. The smaller ones are much higher quality and are from Casey's Wood Products. These don't look like much now, but should look great detailed and on pallets, maybe even with shrink wrap.
Spoiler Summary: Painting up batches of barrels
Spoiler
    Melankolik
  • 2,586 posts
Looking good (as ever) :thumbs
Overground pipes http://www.manticgam...industrial.html and chainlink fencing (expanded ally mesh used in car bodywork repairs can be cut, stretched and suspended from bits of thin ally tube) is always good for Industrial Complexes.
A company called Diopark make 1/35 scale cactus models which (if you can get them locally) might help with the desert terrain.
Snarknit Grokguzz
Snarknit Grokguzz
  • 413 posts
This is looking great so far!  The different themes will work well I think, as you have them planned out here.  I think you've found some excellent pieces to match each area in ways that make sense.
  • 479 posts
Keep the good tips on bits coming.
    Melankolik
  • 2,586 posts
I can do that :biggrin Forgot bean tins as storage tanks, could use them for oil storage tanks industrial and possibly double up as water storage tanks for desert.
  • 479 posts
Spoiler Summary: First glued pallets, test fitting in trukk, Barry supervising test primed set.
Spoiler
Trukk still has lots of work to do until completion; things like hubcaps, spare wheels, chrome fuel tanks, and more painting detail.
I also need to make the forklift-style attachments that allow a dred or kan to grab the attachment and load pallets like these into trukks
  • Snarknit Grokguzz likes this
  • 1,084 posts
As someone who spent a good five years driving forklifts fit a living, I must say I'm rather taken with the idea of using dreads with forklift attachments to load trucks. This is not to say that I think it's the safest or most efficient way to do things, but it sure would keep the truck drivers in line!
Snarknit Grokguzz
Snarknit Grokguzz
  • 413 posts
what a great terrain idea!
  • 479 posts
Spoiler Summary: Pallets, barrels, and some test shrink wrapped loaded pallets
Spoiler
  • Garr likes this
  • 479 posts
Seems like everyone these days makes MDF shipping containers for heroic 28mm. I am a strong advocate of buy vs make when any buyable option is ever remotely acceptable (since time and cost to make don't usually work to make for oneself.) Regardless, for some reason I decided I needed to make some too (in the wee hours yesterday morning.) Below are some friction-fit test copies of version 1. Both short and long versions.
Spoiler Summary: Short and long container prototypes, and palletized barrels
Spoiler
  • DocNuK and Garr like this
  • 479 posts
Recent progress with the containers, pallets, and other terrrain. First pic shows earlier stockpile and container construction from a week ago. Second, a couple buildings (of the 5 I have made.) Third is construction tonight and much reduced stockpile. Fourth shows palletized barrels, barrel stockpile, 75 or so painted containers (about 50 only constructed in last photo), a bunch of GW terrain accessories, and some O and HO scale train liquid cargo containers. Pallets in rubber bands still need painting. I need to grab different spray cans since I already sprayed the colors that were on hand tonight.
Spoiler Summary: Container construction, pallets, prototype large buildings, cargo for pallets
Spoiler
  • 479 posts
150 containers cut out, 80 more containers constructed, 70 more containers painted.
Spolier Summary: Trays of cut containers and two prototype shanties
Spoiler
  • 479 posts
Shanty progress. 50 still just cut. Over 100 base coated (pictured below), of which about 50 with paper roof and about 50 with roof unmounted. Many cans crimped into metal roofing, but not installed yet.
The upside down buildings are ones drying with paper roof glued on.
Example model showing rafters with glue, strip of bag to simulate plastic tarp under roof, and paper roof not yet glued on.
I originally thought I would need to paint and detailed the sides much more, but with the roof tops attracting most attention, I think all that time can be spent focused on distressing, rusting, and weathering the tops.
Almost 300 of the 5 inch containers built of which about 70 are painted
About 30 of the 2.5 inch containers built
About 80 of the 4 inch containers built, with about 30 more are cut
About 50 loaded pallets made, of which about half are shrink-wrapped
About 300 more empty pallets made and painted
About 20 containers made to be shantys constructed
  • DocNuK and Snarknit Grokguzz like this
  • 479 posts
Glued the roof on all the built shanties (except 1)
Sprayed red primer on many to get the base (paper) layer rusty looking, before I put on small pieces of crimped aluminum cans
Even though the sides of the buildings are much less noticeable with the roof on, I still have a huge amount of weathering to do
These buildings will get cinder blocks and tires glued to the roof, exhaust stacks, wiring, posters, graffiti, and other detailing
Spray painted more containers in batches. Still have many to go, but it is very fast to paint them with rattle cans like this.
  • 479 posts
Finally got the first batch of cargo palletized and shrink-wrapped, about 100 pallets. I still need to hit these with a heat gun.
Three pallets are bound with cables. Two example loads in the back of the trukk.
Got the tops of the containers in the last post painted too.
  • 479 posts
Rattle can batch painting is fast. This new batch took a couple hours of lazy Sunday work. Only 64 built containers left to basecoat.
Then I have a huge pile of weathering to do on these containers and the shanties.
  • 479 posts
Touching up some terrain for a 10 player, 20K points total skirmish this Saturday, Orks (freedom) vs. Imperials (tyranny)
  • Garslag likes this
Aslomov
Aslomov
  • 145 posts
  • Location:United Kingdom, far north of Scotland (Thurso)
I am loving all this terrain! :)
What did you use to crimp the metal cans with? I have been looking for a crimper for a while now, but they are all far to big a size.
In the grim darkness of the far future there is only little plastic men.
Also tagged with one or more of these keywords: terrain
