NOB to MEGANOB conversion
Waaagh_Baron
Waaagh_Baron
  • 393 posts
  • Army Name:Sky Rats (AoS Pirate Goblins)
Right I've been asked to make a tutorial, personally I think youtube video I posted in my build log was good enough.
Video in question:
He made three great models.
So Here is my best step by step assembly guide.
Golden RULE:
I AM EYE BALLING ALL MEASUREMENTS DON'T ASK ME FOR A MEASUREMENT I DON'T KNOW!
Tools:
  • Superglue
  • Ruler
  • Box Cutter (or some other model knife)
  • Clippers
  • Tweezers
Materials:
  • A nob, I used ones from the Nob box and an old Assault on blackreach nob
  • Plasticard (030")
  • A garage sell sign
  • Plastic Rod & tube for the pistons (I used Evergreen Plastics 217, its an all in one kit enough for 3 nobz)
Step 1: Model Prep:
Right here is the base model I am working on he's an old conversion with a peg leg.
Before:
After clean up:
Right this next part is important, trim away the raised parts on the chest and  cut away anything hanging on the belt:
Step 2: The boot:
For this start by gluing a spare bit of sprue onto the base of the shoe:
Next to make it easier to I glued two small pieces of card onto the extenstions. The bottom piece of card is going to broken off so don't use too much glue on it:
Because this guy has a higher heel I made the back of the boot first using strips of card that I glued into place, you'll notice they are long but thats not a problem you'll uses a pair of clippers to trim it down:
The next part is trimming I used my clippers some sand paper and my hobby knife its really easy just remember to give you glue 5 minutes to set:
The final part is the front of the boot, Just take another strip of card and bend it so you can make the front round keep it extra long, glue it into position then trim after the glue has set. To make the top band I just used a think sliver cut from a garage sale sign:
I noticed that I forgot to add a tab to the end heel, but I fixed that,
next well make the lower backpack.
The Best Custom Track and Wheel can be bought here:
http://stores.ebay.c...Skulls-Industry
Waaagh_Baron
Waaagh_Baron
  • 393 posts
Right so I am back here is the next part, these models take longer to make when your making a Tutorial, lots and lots of pictures.
So start with some meduim size rod and tube, like I've written before use  the stuff from  Evergreen Plastics 217 you'll have more than enough to make 3 of these guys.
Glued in position, notice that the nubs sick out a little wider than the boots:
The next part is making the bottom part of the armor, you'll need to "roll" it be gentle it will take a moment, then it on:
It rolls around to the back:
With this done, I made the backpack. The Assault on black reach nob has a bent back but I just added a flat plate. The barrel thingy is off the flame thrower for the Deff Dread I had the bitz in my box but anything that looks engine like will work:
Right at the point STOP!, you'll want to do some detailing before contuining the Pistons on the legs will make riveting and detailing a real pain, I added spikey bits to the boots and a lot of rivets:
(also on a side note I rebuilt the Bionic leg to be more orky)
Waaagh_Baron
Waaagh_Baron
  • 393 posts
Right the next part are the pistons, if your using Evergreen Plastics 217 kit you have plastic rod and tube for this. I ran out of rod so I am using Brass Rod, you can as well but it just takes more time to cut:
The piston assembled:
Here it is glued in place, notice that the top connection is a bit tenuous, we'll reinforce it the next step:
Notice this small bit of plasticard between the two pistons I glue it in after placing one of the pistons the blue the other to it.
Once you glue on all your pistons add some small bitz of card to the ends (notice they are extra long glue them on then when the glue sets trim them to length)
Long tabs:
Trimed ends:
You might also want to add some more rivets at this stage.
Waaagh_Baron
Waaagh_Baron
  • 393 posts
So to finish off the lower pistons you need to add the "caps" I made them from a garage sale sign cut into small squares then I cut a corner off:
Wait for the glue to set then trim and finish boxing it in:
And then add details, and rivets to them, also add a bar to the top of the backpack for the arm pistons:
Waaagh_Baron
Waaagh_Baron
  • 393 posts
Sorry for blurry pictures, you can skip this step of modeling if you have extra power klaws laying around I ran out.
THE KLAW!:
To start I used some square stock laying around its about the size of a nob hand:
Next I made side panels for it, this is 030" card:
To fill the gaps I used thin card, in this case the garage sale sign:
Next was adding it to the arm this makes handing the model easier as you add parts. Also notice that I used a bit of tube to connect the arm to the klaw, also I added a small spacer of plasticard to the arm this will help when you add the arm to the model:
I added some details to the klaw itself by adding more layers of plasticard:
To make the klaws themselves, I laminated two sheets of 030" and the cut it out:
The lower Klaw is easy I used a nob Huge Choppa for parts:
And glued it on:
To add the top klaws I used a bunch of smaller bitz:
Waaagh_Baron
Waaagh_Baron
  • 393 posts
Then add small pistons:
Right klaw is done, lets armor up the arm, I just eye balled the sizes, once again 030" card that I rolled to make the armor:
The important part is adding this raised bar to link the armored plates together:
At this point add details rivets and other stuff:
Attach the arm, it will look a weird at this point:
Then add pistons like those on the legs:
 You'll need to wrap then piston top like the lower legs, now basically your done with the tutorial repeat this step again for the other arm, I'm doing double klaws on this guy.
