Ghost's Epic Waaagh
9 replies to this topic
Spectrar Ghost
Spectrar Ghost
  • 45 posts
I've finally gotten up the stuff for a little Waaagh! I started Epic when E:A came out, and have 12k of Panzees, 7k of Steel Legion, and 4k of Baran Seigemasters. I got a bunch of E40K Ork sprues in a bundle a few years back, and they've sat unused. My local SG Club (Chicago) is getting together a big (something like 40-50K total) exhibition game set up for early June, and found ourselves long on pink, and short on green. I already had plans for a footy Ork army, with no vehicles whatsoever, to contrast with my Mech heavy SL and panzee. So I set about geting a Waaagh painted up (finally). In keeping with my footy theme, current plans are for 3k of Orks, including:
1 Big Warband with Warlord
1 Big Warband
3 Big Warbands with 6 Big Gunz and 2 Oddboy Upgrades
1 Big Kult of Speed made entirely of Warbikers.
1 Stormboyz Warhorde
I've put Nobz, Gunz, Bikers, and Oddboyz on kustom bases fabricated from .040 sheet styrene. Nobz are on 40mm x 12mm bases with only 4 holes.
Others are on 20mm x 20mm bases. Gunz are 2 Lootas and a SAG in a triangular formation,
Oddboys are beakie/TL Traktor Kannon. Bikes will be 2 to a base when I decide how to fabricate the bases.
My first Warband (with Warboss) is painted up. This and the other Plain warband will be Goff.
Nobz command with Warboss
Nobz
Boyz with Banna Wava - the Glyph is from the 40k transfer sheet
Boyz
Grotz
Group shot. Only the test stand has static grass so far, but they will all get a patchy covering eventually.
Next up is the first of the Warbands with Big Gunz, in Deffskull colors. I've got the gunz done except for tha bases, but the rest are very PIP. Pics upon completion.
Incidentally, I'm still looking for 2 Traktor Kannon. If anyone has some to spare, drop me a line. <Found. Thanks Verm1s.
Edit: my Epic stuff in it's entirety can be found at AWC/Epic Discussion
SG
Epic: Armageddon
Are you a soldier, or are you a general?
Guest_Nazbag_*
Guest_Nazbag_*
Looking nice, it's good to see someone starting an epic army. I should have a couple of the old plastic Traktor Kannons going.
Zog
Zog
    Wants Panzies
  • 484 posts
  • Army Name:Zogs Boyz
Goff's then? Looking gud :thumbs
Gone crazy.... Back soon....
Spectrar Ghost
Spectrar Ghost
  • 45 posts
I'm planning on doing klan specific formations. Goffz for the 2 unadorned Warbandz, a mix of Deffskullz and Bad Moonz for the Warbandz with Big Gunz, the Stormboyz will be Blood Axes, and the KoS will be Evil Sunz (sic). Half the KoS will be Boarboyz models - may do those as Snakebitez, or may hold off on Snakebitez for a future (not terribly likely) Feral army. However, I also have like 2k of Baran and 4Ks worth of fortifications, some of which I need to build still, to paint for the Big Game, so I may do more Goffs to start as a time saving measure. I'd then diversify on my own time. You know, I'd never noticed the forum automatically translates other armies to the Orky equivalent before the OP...
SG
Epic: Armageddon
Ghudra
Ghudra
  • 493 posts
Nice work. :D The static grass looks solid & helps to camouflage the circular bases. It almost has a swampy feel with the darker brown of the bases. Having those nobz bases reworked to fit just 4 looks great.
Spectrar Ghost
Spectrar Ghost
  • 45 posts
Thanks. I'm really happy with how they turned out, given the whole warband took about 3hr to paint. THe bases aren't reworks so much as scratchbuilt. 2 pieces of 12mm x 40mm .040" sheet. The top one has 4 holes from a standard 1/4" hole punch, cleaned up with a drill bit (the punch is like half a mm too small). Glue 'em together, and rounded the edges with my trusty emory boards. The Stormboyz are gonna get the same treatment, as they are kinda wide too.
SG
Epic: Armageddon
Spectrar Ghost
Spectrar Ghost
  • 45 posts
No pics yet; I've been lazy on my brushwork recently. Soon, I promise. The Deffskullz Warband is about half finished at this time. However, I've gotten the majority of the army built, at least. Of the 140 stands in the army, I have: 8 Grotz, 12 Boyz, 16 Warbikez, and 2 Traktor Kannon left to assemble. Still waiting on the Traktor Kannon, but I've at least got some "Trakked" down now. :whip I've finally decided how to base my warbikes. 30mm x 20mm base with no holes. I cut the bases molded to the bikes off with a razor saw. That way I don't need to worry about putty or figuring out how to cut out matching slots. Not sure if I'll be able to use the Warboars with that method, though, as the contact points are pretty teeny. We'll see. May need 16 plastic warbikes in the near future. Edited OP with link to ALL my Epic stuff, over at AWC.
SG
Epic: Armageddon
Spectrar Ghost
Spectrar Ghost
  • 45 posts
It's been a bit. The Orks have taken a back seat to the Seigemasters I need to get done as well. However, I took a break from painting grey to get the second Warband done. It's in Deffskull colors, and is one of the three with attached Big Ginz.
Full formation - 4 Grotz, 4 Nobz, 12 Boyz, 4 Big Gunz, and 2 Soopagunz
Soopagun (beakie era Traktor Kannon), Big Gun (2 Lootaz and a SAG)
Grotz, Nobz, Boyz, and Boyz wiv Banna Wava.
They came out well, I think, but I will probably wait to do Moonz until after BfLP. They take too long to undercoat. If I have time, I will try. Otherwise they get Goff colors.
SG
Epic: Armageddon
Spectrar Ghost
Spectrar Ghost
  • 45 posts
Managed to build the Warbikes I have available.
I still am short 7 individual bikers, so if you have a lead on plastic Warbikers, I'd be much obliged.
Also 'fixed' one of my beakie Battlewagonz. Thanks to Ghudra for the inspiration here, though the execution leaves something to be desired.
It's not as neat as I'd like, but I've got more tries...
I have a stack of Gunwagon hulls wothout turrets, and a stack of Medusas from my Armas, so I figured I'd kill two birds with one stone.
I really like how this one turned out, unlike the Battlewagon.
That's all for now.
SG
Epic: Armageddon
Spectrar Ghost
Spectrar Ghost
  • 45 posts
Little side project. A friend has asked me to rearm (no pun intended) a couple of Slasha Gargants he got without weapons. One he has, though I need to do a CCW for it. This is the second, though I need a right Soopagun arm.
Soopagun. Yes, it's a cut down Autocannon.
Gargant CCW. The blade is from the Boyz sprue.
The arms are pinned so as to be interchangable.
SG
Epic: Armageddon
