GargDregga is looking to the skies!
58 replies to this topic
The last set up is the most unoriganal, but with that said it does look the best ;) I dont like the wing shape. Id much prefer them to be simple triangle shaped, like a MIG ;) But that wont work now the engines have been shortened. So just square them off a bit ;)
Quase
Quase
    Big Mek
  • 4,200 posts
  • Army Name:Da Klan ov da Golden Teef
In pics # 1, 2, & 4, the engines look 'angeled'. When I try and straigten them, I have a problem with the front of the engine being away from the hull, and the rear of the engine being flush up against the hull. Should I bother to straighten them, or leave them as is in pics 1, 2, & 4?
Leave them as in the piccies :yes
As Kr00zA said, it might not be the most original thing to do but it looks guuuuuuuuuuuuuuuuuud
As for the nose, difficult to say immediately... Do you have the bit at hand that should be glued there? It might give us some idears :yes
Roight, any questions?
Yes?
Too bad!
It be time to WAAAGH!
Quase -
Warboss GargDregga
Warboss GargDregga
  • 1,081 posts
  • Army Name: Waaagh! Dregga or Klan Dregga
I thought so as well (most unoriginal), but it does look the better of all the things I have tried. I am doing my best at trying to keep this a simple build (my first attempt and all), so rebuilding the entire wings was very unlikely to happen. (My Plasticard-fu isn't good enuff to try that just yet, at least my confidence isn't). I have every plan to square off the ends of the wings, I had actually forgotten to do that. Might get that done right now actually...
**5 minutes later**
GD
Yeah sure, here ya go...
Off the front.
[attachmentid=14917]
On the front.
[attachmentid=14918]
[attachmentid=14919]
Behind this goes the standard 'engine' for the Propellor.
GargDregga
... IT'S MADE OF PLASTIC!!!! - KROOZA
"I can fix dat." - Gooba - Baltimore Gamesday 2006.
Waaagh! Dregga Medusa V Game Tally: Ranked 5th overall in AUS/NZ region. 102nd Globally.
"Yeah, we flew our space church across 500 light years to get to this planet taken over by the orks. Now we're going to drop from orbit in buckets and run out and shoot pistols and hit people in the head with chainsaws. Ultramarines!" - Zack
Id go for a nose cone. Most every FB Ive seen has a intake mounted on the nose so do something different ;) And with the engines mounted on the sides it realy doesnt need an intake on the nose ;)
Dangerous_Beans
Dangerous_Beans
    Paint Squig
  • 100 posts
I also think you need a nose cone type thing at the front. There is no need for an air intake and I don't think a nose turret would look that good. Rather than an actual cone I think a wedge/pyramid cross might look good. So like a wedge but with the thin edge about 2/3rds of the height of the body of the plane.
  • 3,752 posts
I feel the need for a nose cannon. :dakka Maybe it's just me but when I see the front end of this thing I picture the end of the movie "The Mask" where the Mask is facing down the bad guys and pulls out two "guns". Looks great so far. :thumbs
Scarpia
Scarpia
    No Gud Lootin' Git!
  • 5,709 posts
  • Army Name:Warboss Bobz Killa Konvitkz
I guess I'm too late. I like the one where they were mid wing, it would be easy to beef up the structure with plastic ibeams, you could have run them like the old support wires on early monoplanes that ran from the wings to a central post. Either way, looking good!
meh.
Warboss GargDregga
Warboss GargDregga
  • 1,081 posts
Heya All;
Thanks for the feedback so far. I have done a test fit of an 'extremely roughly done' nose cone, and the body shape/length/size just didn't lend itself to having a cone'd nose, sorry all.
I have toyed with a few ideas, but nothing seems to look right at all. Even the idea of the verticle wedge (which I really liked) just looked awkward, and wrong.
I have ended up almost keeping the... bluntness of the nose, but have given it an angle at the same time. I won't try to explain, hopefully the pics will show what I was trying to achieve.
At the front of the plane, I added a 10mm wide tube od plasticard. I then cut the tube diagonally so that the top of the tube was 10mm wide and the bottom of the tube is 5mm wide. It looks bad at the moment, but with armor plates it should meld nicely with the rest of the fuselage...
I then covered the front of the fuselage/nose with a peice of plasticard cut to shape. Where the (highly artistic :rolleyes ) impression of the teef are, is where armor plates will be used to create the pattern. The teef will continue around the sides of the nose and along the fuselage and end just at the beginning of the engines. The 'armor teef' won't have a gap as large between them as the one in the drawing...
Thoughts?
GargDregga
[EDIT]
Sitting here looking at the model, I thought the front looked to 'cornered/square/sharp' on the edges. Then it dawned on me. I test fitted the actual nose-front peice of the model, and it worked! The sharpness of the edges is now taken care of, and the look is alot better...
I think so anyway. ;)
[/EDIT]
Edited by Warboss GargDregga, 06 October 2006 - 09:45 AM.
    Dethkopta Pilot
  • 1,728 posts
  • Army Name:Freebootaz
ooh... shiney.... I like that alot. I'm going to stick in the obvious dags around the nosecone bit and suggest some random hoses/fuel lines running from the open space down to the engines. I work with aircraft and have a few notes about that in particular (I will try to send engine pics but have to do it from a non-gov computer...) hoses tend to run however they need to but fuel lines run in sharp-ish bends (usually between 45* and 90*). The wings are actually the perfect thickness and if you do armor plate do not use 1mm that is WAAAAY too thick. On a side note, I have to admit I hate seeing the conflict our input is causing, I'd hate to think I'm causing more harm than good.
The Orks are the pinnacle of creation. For them, the great struggle is won. They have evolved a society which knows no stress or angst.
Who are we to judge them? We panzee who have failed, or the Humans, on the road to ruin in their turn.
And why? Because we sought answers to questions that an Ork wouldn't even bother to ask.
We see a culture that is strong and despise it as crude.
Captain_Vyper
Captain_Vyper
  • 308 posts
OK so its not super original but how about extending the nose out at the top like the FW one sort of like a shark. ( a bit more than you already have that is ) Then strap an iron gob on the bottom. Its not very aero dynamic eithe but will look cool and its very Orky!
Ya know, we should sculpt some female Orks. What!? Yeah the customers want em and I think we can sell em besides they have to come from some where. I dont know about that. Well whats your idea? Lets make em come from mushrooms! ........?WTF!?
http://www.pbase.com...vypers_pit/root
Well if its not a cone then Id like to see something sharkish like this...
Groms
Groms
  • 136 posts
Looks like the bomma is coming algon great :thumbs . I like the idea of a shark look, give it that mean look. I do have one question though. Have you ever used a bomma in a battle, and if so how did it work out for you? :cheers
Captain Destructo
Captain Destructo
  • 526 posts
  • Army Name:There isn't one.
Um. *Waves arms around frantically, trying to communicate idea*. :!
I was thinking you should have the air intake above the nose, muscle-car-esque, and keep the teef idea, they're so orky. I've drawn a picture (as much as it might look like an angry face, it's the teef with air intake and twin linked BS-type thing above them. The magazines are \/ shaped so the pilot can at least have a good look at what he's giving some dakka to). That's the idea, anywho. :blush
Warboss GargDregga
Warboss GargDregga
  • 1,081 posts
'The Open Space'?
Pics would be very much appreciated, thankyou.
Unforunately, I only have access to either 0.9mm or 1.4mm thickness plasticard (in my area), so I was going to go with the 0.9mm for armor'ing up the plane. I do also have some 0.2mm plasticard (paper thin), but that would be useless to use on the plane itself as I want to do 'sunken rivets'.
NOT AT ALL. I thrive on the conflict. Please, everyone keep the ideas rollin' in. I might not use alot of them, but at least the ideas are put forward. Without them, I would've ended up with a small fuselage with two HUGE engines just sat ontop of the wings... :puke . It has been everyone's ideas that has gotten me to where I am now, and they are EXTREMELY APPRECIATED!
GargDregga
*Waves back at Mad Bazza and thinks about calling lifeguards, then realises what is going on**
The 'front' of the nose isn't going to be an air intake port. The teef are just gonna be there fer show/armor. With the TLBS, I am trying to decide at the moment whether I want a Grot gunner behind the pilot, or to have the TLBS up front (where you have it). I haven't fully decided on that yet.
GargDregga
    Dethkopta Pilot
  • 1,728 posts
The "open space" would be more accurately described as the dead space where the new plasticard is on the nose cone... though I'm not sure that there's that much of it after looking again... I'm coming down with something so I may be a little out of it... :sowhat
I told you there'd be pics and here they are!
(note: these are from underneath and the panels that normally conceal this stuff are lifted for maintenance)
EDIT: what about a tiny ball turret with a snotling?
#56
deamoncow
deamoncow
  • 1,031 posts
  • Army Name:Da Gear Boyz
have, from in between the teef, a TLBS sticking out like a toung. or have a snot in there trying to do repairs mid-flight
WAAAGH DA GEAR BOYZ!
Warboss~Gregza Un Bonzif da Stompy
Big Mek~Big Mek Dogbreff
If there is an Ork Stompa released by GW anytime this year I will eat my own genitalz winkingOrk.gif
~Kr00za
I'm holding you to this Kr00za, you better do it. Pics or medical forms as proof
HAMPSTER SQUADRON my webcomic! http://hamsquadcomic.googlepages.com/
#57
    Dethkopta Pilot
  • 1,728 posts
deamoncow good call.. a grot in there would be great, i think the squashed snot/grot from the giant sprue tucked in there would be cool, it'd look like he got sucked in and flattened against the vanes
#58
deamoncow
deamoncow
  • 1,031 posts
i was thinking more of a grot holding on for dear life as he tries to rivit one last toof in...
~Kr00za
#59
ghaleon88
ghaleon88
    Gargant Krew
  • 2,848 posts
  • Army Name:Grotsbane's Krumpas
Darn... I was really hoping for the wedge nosecone. I think it would be most easily acheived if sculpted from milliput, rather than plasticard. Anyway, like Scarpia I really preferred the middle-of-the-wing jet engine arrangement. It reminded me a lot of the SR-71, which somehow didn't get its wings torn off despite very powerful engines. Somehow, having them against the hull makes it look less fast - I'm not sure why. Something to do with "visual weight", I'd assume.
Sneeky invisork: 4 2 3 4 1 2 2 7 5+
