Scratchbuild Big Squiggoth for Snakebites
- - - - - Squiggoth Snakebite
16 replies to this topic
    Warbuggy Gunner
  • 1,618 posts
Apologies, I haven't posted for a while.
Anyway, I've recently invested in some Savage Orruks to make my next clan with, as I wanted some Feral type Snakebite Orks to go with my Goffs, Evil Sunz ect.
I'm still waiting for my new boyz, but as a side project to keep me enthused, I looked into making a squiggoth for them. I can't afford a FW one, and to be perfectly honest I didn't want one as it's too metalic looking. I wanted something more feral. So, after a bit of research online, I found a suitable model to base my squiggoth on and ordered it.
It was a Tamiya : 1:35 scale Triceratops Eurycephalus. I then started making a Howdah out of some bits of an old trukk and a scrapped Goblin wolf chariot. Here's what I came up with.
t.15232143_1360651580613155_14482054230261
    Warbuggy Gunner
  • 1,618 posts
15241924_1361110543900592_37361591111292
Scale comparison to a battlewagon
    Warbuggy Gunner
  • 1,618 posts
After a lot of messing about to get the skin correct, here is the near completed model. I can post the step by step if you'd like, but it's picture heavy.
https://scontent-lhr...9da&oe=58B77286
    Warbuggy Gunner
  • 1,618 posts
For some bizarre reason I can't reply, so I'll try the quote option and see if that works.
Thanks for the feedback  Badfang. I've changed the picture link to my website instead of my facebook page so the updated pics should be accessible now.
Scale wise, the Big Squiggoth seems to be somewhere between a trukk and a BW, with the howdah being a bit taller than either, (A BW with ard case and all guns attached) I took a gamble on the mdel as it was only €10 plus postage, and was being mailed from within the same country so cheap cheap, rather than €100 for  Frogeworld alternative. The Gigantic Squiggoth is about the size of a stompa on its side, so the nearest alternative I can find to the FW model is a Mamuk from GW. (Possibly a future project).
After some trial and error on painting the skin of the beastie, I'm very happy with the outcome, so I might buy another couple of them too
    Moronik
  • 2,496 posts
Thought I hadn't seen your name for a while :biggrin
Beastie looks proppa although I'm surprised at how small it is (1/35 is about 150% of the nominal 1/56 that 28mm is usually rated at - I thought those things were bigger than that, still wouldn't want it sitting on yer noo buggie though :bang ). Howdah fits well on it, nice job :thumbs
ps Facebook pix weren't working :?
    Moronik
  • 2,496 posts
https://wordpress.co...ress.com/158413
.... I've changed the picture link to my website instead of my facebook page so the updated pics should be accessible now.
I've had one or two problems myself trying to reply to stuff - trying again later seems to work usually. Trying to look at the 'wordpress' pix requires setting up an a/c and logging in, is there a 'direct' link option for the pix?
Don't know if you use Milliput or GS but they're both pretty good for spacing kits out to make them bigger. :cheers
    Warbuggy Gunner
  • 1,618 posts
Thanks a million Badfang. I've never tried milliput or GS, though I've seen GS used.
I have tried to stick the pics on Google and Youtube, but I'm not sure it works. The pictures with a partially completed base are the final ones, but as you can see I experimented a bit on hide colours and choices of Pigboy or Goblin Big Boss.
    Warbuggy Gunner
  • 1,618 posts
I think it's the correct size, but if anyone can give me the measurements for a Big Squiggoth that'd be great. I know what the sizes for the Gigantian Squiggoth are, but couldn't find the sizes for the smaller model.
My model is 11cm high to the top of the  howdah, 22cm long from tip of horn to tip of tail and 9cm wide across the horns (8cm at butt) and it fits comfortable on a 12cm oval flyer base, which I've seen other Big Squiggoth based on.
Garr
Garr
  • 335 posts
  • Army Name:Waaagh! Gar'un Mek-Klaw!
Big Squiggoths are 120mm highx 150mm long by 80mm wide, my partner bought me one recently to cheer me up.
  • Garslag and Mik McMok the Mek like this
    Moronik
  • 2,496 posts
Well that saves a lot of scrolling :biggrin  Teefs and toe nails look a bit bright for my liking but the hide looks well proppa :thumbs
Should have thought but Garr's post reminded me of this which is always useful for scratchbuilding
http://www.the-waaag...showtopic=50382
    Warbuggy Gunner
  • 1,618 posts
Thanks for that Garr. I know my model has a longer tail, but that's no biggy and it's slightly shorter in height, but a slightly  thicker base should solve that, and also the banners and flags overcome that too.  I'm reluctant to shorten the tail though. Generally they are pretty close. Much appreciated.
I do hope the gift was a success. It would certainly cheer me up if i got those two beauts.
    Warbuggy Gunner
  • 1,618 posts
Thanks again Badfang. I'll have a look at the teef and Klaws tomorrow, maybe darken them like the horns or another wash or two should tone them down.  :thumbs
And that's a great idea with the dimensions. Thanks for the link.
  • 1,058 posts
As badfang already mentioned, the howdah is really well executed, and a touch of paint seems really to have taken this to the next level.
Since you've mentioned that you're looking at getting a couple more of this kit, I'd like to see what happens if you try shaving off the dinosaur's crest (probably the wrong word, but I didn't see the latest Jurassic Park movie). I think a move like that might go a ways towards making it look a little less like a triceratops. Perhaps you could bodgy up a big steel jaw or something for the new one too?
    Warbuggy Gunner
  • 1,618 posts
Thanks for the feedback Garslag.
I had contemplated shaving off the bony frill (apparently that's what its called) but as I was aiming for a more Snakebite Feral Ork version, I decided to keep the frill and go for a bony jawbone, (which I happened to have a couple of in my bits box). If I get another two, I might try to do one more like the FW version.
  • 3,756 posts
From the triceratops conversions I have seen in the past, removing the bony frill is not a good thing. We have a mental picture of what's going on behind that frill and it rarely matches what the model actually looks like! :lol :scowl That said, it could still be done, but I would expect the GSing involved would be significant. Which is fine if you're up for that and pretty much a requirement if you going to use the same base model and don't want them to be too similar. Of course, there's an argument to having them be very similar... i.e. they are the same sort of squiggoth. Then you would want to concentrate on changing the pose (and howdah, etc.) to avoid the "saminess" (yes, I just made that word up now. I am shameless.)
    Warbuggy Gunner
  • 1,618 posts
I can see it being a challenge to remove the bony frill, that's true. I would prefer to change the leg pose and the howdah style so that they are similar without being to much of a saminess. (It could yet be in the Oxford Dictionary ) :eek
It would be interesting to try and model one in mid-rear, ready to stomp a termie or two.
    Moronik
  • 2,496 posts
You spelt it wrong ;)
Also tagged with one or more of these keywords: Squiggoth, Snakebite
