Iron Goblins (formally The Sky Raidrz)
Sky Pirate Goblines Iron Weld Arsenal Goblins Goblin Steam Tank
48 replies to this topic
Waaagh_Baron
Waaagh_Baron
  • 413 posts
  • Army Name:Sky Rats (AoS Pirate Goblins)
Right I've been playing the Kharadons for some time and well they're not my speed...so I decided to switch up may Sigmar Army and go Iron Weld Arsenal with Steam Tanks and Cannons, here a link to the new part: http://www.the-waaag...e=3#entry729142
So basically, I remembered reading something somewhere about GW thinking about making Sky Pirate Goblinz to tangle with those Kharadon Overlordz dwarves. So I i've been waiting, and then well decided, If GW ain't ganna do it I will. The plan is to use 40k grotz and scratch build the ships, here's my beginning of their IronClad:
Here is the being of their gas bags/ballons/what ever these things are supposed to be:
C&C welcome.
PS: the fiddly bitz of rules and all I am building this as a counts as army for Kharadon Overlords.
  • warhead01, armored walker, 4tonmantis and 1 other like this
The Best Custom Track and Wheel can be bought here:
http://stores.ebay.c...Skulls-Industry
Waaagh_Baron
Waaagh_Baron
  • 413 posts
So I spent this night giving the model a couple of hours of work. The main "plating" on the hull is nearly done, now I start detailing, mainly rivets and portholes. The "engines" I'm waiting on some bits, also after I finish the rivets I can add the smoke stacks to the model.
C&C welcome, encouraged and well, I'll admit it I run on complements when I am doing these projects.
  • Badfang Brassaxe, Dok Gubbinz, Garr and 1 other like this
  • 2,567 posts
:lol
Got a pretty good cross between a U-boat and a MTB going on, assuming that you'll be putting in a forward turret and a deck gun at the back of it and the lifta-gas-bags over the top? Interested in seeing how the funnels are going to be routed. :cheers
  • 1,081 posts
Looks pretty promising so far. No idea about the AOS fluff to know what you're using it for, but it looks promising.
Dok Gubbinz
Dok Gubbinz
  • 7 posts
Excellent work!
Waaagh_Baron
Waaagh_Baron
  • 413 posts
:lol
Thanks, I was going for more U-boat but well it worked out. The forward gun I've not totally decided on what its going to be yet. As for the lifter bags I got a plan, just want to finish the hull first.
Thanks, as for rules this is going to be a counts as army for Kharadon Overlords.
Excellent work!
Thanks!
So I started detailing work, the rear section is nearly there:
C&C welcome.
Waaagh_Baron
Waaagh_Baron
  • 413 posts
Right I know most people don't care much about detailing work, but I finally got the preliminary riveting done.... and started to build out the exhaust.
C&C welcome.
  • warhead01, Orkimedez, Dok Gubbinz and 1 other like this
Garr
Garr
  • 352 posts
  • Army Name:Waaagh! Gar'un Mek-Klaw!
Look8ng great, i'm looking forward to seeing the crew.
Dok Gubbinz
Dok Gubbinz
  • 7 posts
It's quite often the detailing that makes the model. Very evident in this case - it's looking incredible, even at this stage.
  • 2,567 posts
Yeah, I guess that works for the exhaust - I was kind of expecting a couple of more steampunky type funnels going up and round the gasbags but dieselpunky is probs orkier :thumbs
    Dethkopta Pilot
  • 1,730 posts
  • Army Name:Freebootaz
I'm jealous. I bought some of the fantasy dwarf airship stuff to do something.. somewhat similar and was underwhelmed with the size. You've done a very convincing job to this point.
The Orks are the pinnacle of creation. For them, the great struggle is won. They have evolved a society which knows no stress or angst.
Who are we to judge them? We panzee who have failed, or the Humans, on the road to ruin in their turn.
And why? Because we sought answers to questions that an Ork wouldn't even bother to ask.
We see a culture that is strong and despise it as crude.
Waaagh_Baron
Waaagh_Baron
  • 413 posts
Thanks, my main plan is I got a bunch of 40k grots, I see pirate hats, and that might be it for them. I also have some kharadon pistols which I might use for them.
Yeah it's looking better and better as I work.
I would have gone steam punk but well I do like the Disealpunk a bit better also I might use this as something for 40k eventually.
I actually have 2000ish points of Kharadon, which I play right now, I plan on the Gobbos replacing them.
Well I have family visiting soon so I spent a little bit detailing. I added a second exhaust stack to it.
C&C welcome.
  • warhead01 and armored walker like this
armored walker
armored walker
  • 528 posts
Shaping up nicely. :thumbs
As for crew, Kromlech makes some pirate goblins, and Maxmini has some pirate gobbo heads - no idea about the size of those, though.
Armored walkers are Slow and Purposefull.
Waaagh_Baron
Waaagh_Baron
  • 413 posts
Thanks.
Well I have looked into that, I do have a few Pirate Grots from my Gorka Morka gang somewhere. Pirate hats are easy, personally I might go Steampunk Gobbz its an idea i have bouncing around.
So small update, not sure I like it but this is my first "gas bag" according to Fluff its actually a metal that is lighter than air. (cool fluff from the Kharadon book)
And the work on its base, I need to add some more rocks for detail and weight.
C&C welcome.
  • Dok Gubbinz likes this
Waaagh_Baron
Waaagh_Baron
  • 413 posts
So another small update, I changed the Gas Bag.... lift thingy supports. I wanted something that looked lighter, but I needed structure so I made the extensions out of brass rod.
A better close up, right now it has a magnet and a pin so I can remove it to work the model and paint later.
C&C welcome.
  • 2,567 posts
Can see good arguments for both - the gasbags want to look light but they are expected to drag the boat up with them and need to look sturdy enough to do it.....
Do think that the mk2's look better :thumbs
Maybe see about some sort of netting over the tops of them :?
Waaagh_Baron
Waaagh_Baron
  • 413 posts
Well as the Fluff does state the gas bags are actually metal made from lighter than air material, I'm not too sure about the netting. I might go a bit more on the detailing that's probably it.
Well as I wait on Amazon to deliver more supplies, I started in on its main weapon today, a Sky Kannon. The local players around here play stormcast.... AKA good armor I need something with a big Umpft to it.
Mounted on the ship:
The mounting is a 40mm base which has a metal fender washer under it. The turret mounts 3 magnets, and a pin which holds it together really well.
C&C welcome.
  • warhead01 and Dok Gubbinz like this
Waaagh_Baron
Waaagh_Baron
  • 413 posts
So I started the Propeller, spent way to much time working on it, too little time sleeping tonight:
Temp Tacked on with blue tack:
C&C welcome.
  • warhead01, Dok Gubbinz and Tomas Azmond like this
  • 2,567 posts
Love it - dat's a most proppa lookin' werky bit :thumbs
Waaagh_Baron
Waaagh_Baron
  • 413 posts
Gosh I hope it looks good, it took way longer than I was expecting.
So update, I got the supplies to make the main gas bag. 140mm empty Christmas ornaments, I started to make the atatchments, the gas bag actually dis connects right now to allow for detailing and painting, I'll glue it into place once I finish.
IMG_20180718_222055500_LL_zpscwgr9zh1.jp
And a painted Gobo, with a pirate hat:
C&C welcome.
  • PeaceCraft, Dok Gubbinz and Tomas Azmond like this
