Stable Pix Blog?
189 replies to this topic
#181
  • 2,100 posts
Cheers for the response Giga and apologies for the delay in answering - been trying to get stuff worth posting done but mainly making virtually no progress but a lot of scrap :bang (don't think mega armour was designed for sitting down in, or for riding warbikes >: ).
P.S. A Warlord Titan banner would easily make the "ridiculously oversized" classification.  ;)
Hur hur - I fink FW sells titan bits :D
Started work on the two twin rokkit launcha turrets for my skull'amma
L-R Radius arm for one side of the 'ball' turret (other arm's already fitted to the uppy/downy bit that the 'gunner' sits in), next to that is the assembled part Milliputted ball turret - the brass rod is there to make sure that the Milliput bosses have holes through them that line up correctly, once both sides have been done the rod will be replaced by two smaller rods so as the gunner can sit in the middle. Then there's the part 'putted 'turret' that will have the ball turret rotating 'up' and 'down' in it (again the rod through the middle will be replaced by two shorter bits) and at far right there's the bits of the turret part assembled hopefully showing the bits that have gone into them.
I've used tinplate 'coz it's what I've got - it can all be duplicated in plasticard if blocks of sprue are used to reinforce the glued edges and the 'ball' turret is pretty much the same thing as a gun mantlet ('cept bigga, wiv an ork in it :lol ).
In other news
I've redesigned the new spare trukk engine a bit so it's about Wazzy sized and rooted out a back 'wheel' for it and I'm mostly done with Wazzy's mega armour - see if I can get stuff worth photo-ing tomorrow :cheers
  • kreell and Giganotosaurus like this
#182
  • 396 posts
 I looked at all the tin & Milliput, read the paragraph, and thought?  :?  Went out to work in my much too large garden, and came back to reread your thread. It took me a moment, but then I figured out how it all went together. Duh!, the big rod was throwing me off.  :blush  Should work well, I hope the conical towers will fit (where's that fingers crossed emoji?). Years ago, I took a tour of the Garber Restoration facility. They restore all the planes for the Smithsonian Air & Space Museum there. The tour guide took us by a ball turret on display, and remarked that WWII ball turret gunners were the smallest men in their squadrons. Ball turrets also retracted up into the bomber for landing (at least they did on U.S. bombers). I like your Orky version better than a weedy 'oomie one.
I like the trukk engine, it looks like something that will make some serious power.  :love As much as I like the GW trukk kit, I have always thought that the engine could use a little help. The rear trakk drive is a piece of art, well done!!  :thumbs  :thumbs Wazdakka should be racing around the battlefield in style.  :yes
"Hur hur - I fink FW sells titan bits  :D " They do, and they sell transfer sheets. The sheet entitled 'Titan Transfer Sheet' is the one I believe you will want. Alternatively, appropriate images are floating around the internet, just waiting to be downloaded.  ;)
#183
  • 782 posts
This is gonna be great. First I note with enthusiasm that it's gonna be real Wazdakka you're building (i.e. before Chambers stripped him of his mega armour), and then DAT ENGINE! This Wazdakka will make Jazgob and Zhadsnark look like grots riding tricycles... which is just the way it should be :)
  • Badfang Brassaxe and Giganotosaurus like this
  • 2,100 posts
:rolleyes
Thanks guys, found the zappgun that came with the battlewaggon I got and had a bit of a play with the gunshield
the turrets worked for a given value of 'worked'
Yeah Giga, even the orks in these ball turrets needed cutting down a bit but the turrets are going in the big holes each side of the drivers' cab
and it's a sufficiently big wagon that any ork's going to look small anywhere near it :D
Well, most orks :lol
  • Penelope the Wonder Pony, kreell and Giganotosaurus like this
#185
  • 396 posts
The Skullnamma front end is filling in; the hydraulics, and the driver's cupola really help to bulk up the battlefortress' front, the turret towers ought to finish the job.  :yes  Are you planning on some exhaust megaphones for Wazdakka?  :?  They would help finish the powerplant, and fill in the area over the track drive. Something like the Honda 250 & 350 cc, 6 cylinder, Grand Prix bikes of the mid to late 60's, but more exaggerated ( <http://www.motorcycl...sixcylinder.htm> ).  :thumbs
P.S. you're right, mega armor is not designed for sitting.  ;)
#186
  • 2,100 posts
Cheers Giga, been busy doing rubbish so it's taken a while to get anything 'worth' putting up (cheers for the Honda linky - had been thinking about reverse cone megas, depends how much room I get left with :thumbs ).
Did a bit of mucking about with guns -
External mantlet restricts the amount of elevation/depression, big nosed turret would restrict slew in a tight space.
Internal mantlet gives max elevation/depression limited by the amount of space available above and below at the breech end and the size of the barrel, slew is limited by wall placement - too far forward and the barrel gets stopped one end and the breech gets blocked at the other. (Originally wrote more than this about it but my computer decided to interpret me accidentally catching my hand on the touchpad as 'open Pinterest and dump everything I'd just written'  >: )
In other news the big red thing is bigger and redder
Hadn't enough height to do the turret roofs like the old epic one - did what I could to suggest them. Still need the bonnet sides, back door/ramp, exhausts, internal bulkheads.....Are we there yet? :lol
And while I'd got a palette covered in red paint
And I finally got a halfway decent head for Wazzy sculpted - stuck my mega armoured AoBR warboss in the pik as a Barry
So, I aintn't ded yet.
#187
  • 782 posts
Is that the battle kannon in front of the handlebars? You might wanna reinforce it so it doesn't rip it's mounting off when it fires.
  • 2,100 posts
It's an FW killkannon - I had a look at the supakannon and killkannon in the cabinets at FW, the supakannon was stoopid long and the shells that the grots had got for it were the same size for both, and the kk had a better selection of grots (who I really want to be crawling all over the bike). If I can figure out a way to modify the breech then I should be able to knock up some proppa-rer ammo for it, in which case it may have to move forwards and that'll require extra bracing anyway although it is bolted to the engine block same as everything else on the bike is ('cept the flakkagunz).
#189
  • 396 posts
"the supakannon was stoopid long and the shells that the grots had got for it were the same size for both" The A-10 Warthog/Thunderbolt II was designed around the GAU-8 Avenger cannon. Hmmm, a warbike designed around a supakannon, what an interesting concept. Someone may have to devote some time to creating such a thing.  :D
Liking the progress on the bigger, and redder, big red thing.  :thumbs
#190
  • 2,100 posts
Cheers Giga, think the big thing is red enuff for now
Just about done with the mekking part now and I could really do with having my wet palette not covered in red any more >:
