Rivet punches
9 replies to this topic
bigmark268
bigmark268
    Juicy Squig
  • 62 posts
So i was noseing around and jsut stumbled accross these. They do seem awsome for universal sized rivets, bit pricey though. But i saw this and was like im sure someone else may be interested in this. So here they are
MN029 MINI PUNCH & DIE SET PT.6
http://umm-usa.com/o...0d5b5ad9ff4f270
MN030 MAXI PUNCH & DIE SET PT.11
MN031 HEXAGONAL PUNCH & DIE SET PT.4 "Hex"
jackdoud
jackdoud
    Kaptin Kork
  • 975 posts
I'm liking the hex punch. Hopefully they come back in stock soon. :thumbs
Aslomov
Aslomov
  • 145 posts
  • Location:United Kingdom, far north of Scotland (Thurso)
I am sooo gonna buy those! :biggrin I MUST have!! :sowhat
In the grim darkness of the far future there is only little plastic men.
Murrdox
Murrdox
  • 648 posts
Similarly I love the hex punch... but damn those are expensive! Has anyone found any cheaper alternatives?
  • 2,021 posts
  • Army Name:Snotbagz Nozeminerz
Those would be awsome, but as Murrdox said, they're a little out of my price range for something like that. A cheeper alternative would be nice. Thanks for sharing.
ukpro
ukpro
  • 480 posts
  • Army Name:Waaagh Gazbagga
It would also be nice to see a UK stockist :crybaby
jackdoud
jackdoud
    Kaptin Kork
  • 975 posts
I bought this punch set from Micromark a few years ago:
http://www.micromark...H-SET,8603.html
Not exactly cheaper but Micromark runs sales fairly regularly, I got mine for 20% off. I look at it as an investment in my hobby; hold off on that extra battlewagon and the price isn't bad for a tool you can use repeatedly.
Aslomov
Aslomov
  • 145 posts
That looks like a decent one! But I'd much rather have a smaller one.. Like for non-vehicle mini's and the like! :rolleyes
Nexus
Nexus
  • 1,100 posts
If you have the motivation then here's a tutorial on how to build your own punch and die set.
I myself have the Micromark punch posted by jackdoud but I also made a dedicated 0.5mm punch and die set very easily using the techniques from that tutorial.
I had been put off building a whole set because I could not find decent sets of tiny punches that weren't going to cost at least as much as a professional punch and die set but it occurs to me now that a cheap set of HSS drill bits could be used to drill the holes and then the flat ends used to punch the rivets.
Edit: In fact the tutorial even suggests using the same drill bits as punches so I don't know why I didn't notice that earlier :scowl
This is your life, and it's ending one minute at a time.
crispy
crispy
  • 171 posts
Great tutorial Nexus. I did see something similar that used a small allen key to punch out hex bolts. Can find the link anymore but it was a similar process as mentioned in yours. Think the guy sharpen the allen key end to a proper 90 degrees and punched it through a hole just a little larger than the key width. I'll have to give these a try soon.
"When the pin is removed, Mr Grenade is not your friend!"
