Trust in Rust: 2-9-19 Deathskulls Warboss Joins the Crew!
* * * * * 1 votes orks trustinrust warhammer 40k deathskulls badmoonz walkers painting
421 replies to this topic
#341
Boss Ardnutz
Boss Ardnutz
  • 635 posts
  • Army Name:da Maniakz
Nice work indeed. Love the soot, is that done with pigments or paints?
  • greggles likes this
#342
greggles
greggles
    Frantik
  • 2,074 posts
  • Army Name:Trust in Rust
Thank you!
Soot, Dust on lower shields/feet, and the blue glows are all done with weathering pigments.  I especially love the pigments because you can easily remove them if you aren't a fan of the effect. (as long as you don't fix them in place)
#343
  • 1,058 posts
How would you go about fixing them in place greggles? I'm a pigment virgin.
These guys continue to look brilliant. Did I already comment on how into the big orky faces on them?
greggles
greggles
    Frantik
  • 2,074 posts
Hey Garslag!
Thanks so much!  I got a giant bin of mixed jaws and faces, try to come up with some good ones!  I'm very happy with how this guy came out.  The grot knight used to be my favorite!
To fix pigment, there is a few different ways.
1) Most reliable: Pigment fixer.  You can purchase a pigment fixer from Secret weapon, or the company that sold you the pigments (I use SW).
2) Have to get careful: Alcohol.  Touching the pigment with alcohol will lock it into place, just make sure to just allow the capillary action to let the alcohol flow, otherwise the paint will strip!
3) Very unreliable: Using a varnish from a distance.  (Generally just blows the pigments around).
I generally don't fix my pigments. If they wear off, I just add some more pigment later.  These aren't comp pieces, so it doesn't matter if something isn't 100% perfect. I  do them cause I think they look cool as !$&)! on the table :)
#345
  • 1,058 posts
I've often thought about trying pigments. You and others get frankly amazing results from them. However due to some as-yet-unprobed psychological trauma, I really need to have an end point where I never have to touch them again. I've never heard pigment fixer mentioned before but it sounds worth looking into.
greggles
greggles
    Frantik
  • 2,074 posts
I have the same thing.  This knight is done.  I immediately saw something that needed to be done, nope, done.  I just consider pigments the final step.  Touchups are just something you have to do anyway when you play with models.  Things get chipped/damaged through constant play.  It's why so many magnets are on my stuff!
If you do the pigments, i highly suggest getting the entire pigment pack at once.  You will NEVER need more.
http://www.secretwea...fvtfj7682sd9l87
They really are a godsend with effects and such.  I didn't even think of using them for the glow until this guy.  Now I'm probably going to have some fun adding glow effects to everything, since I can easily adjust and blend it with the pigment. (without worrying about screwing up the model, which is always my biggest handicap).  Like right now, I'm going to have to cut a tank off the gun arm to fit the ammo drum on, and I just can't do it yet....
#347
greggles
greggles
    Frantik
  • 2,074 posts
Some death skullz grots for you all!
Spoiler
  • Boss_Grimdreg, warhead01, Lexington and 3 others like this
#348
Boss_Grimdreg
Boss_Grimdreg
  • 204 posts
  • Army Name:Grimdreg's Goff Orkz
Awesome work on the wee lil blighters Greggles!! The deffskull facepaint even looks good on them! Now you getting me to want to do another unit of them!
Current Project: Ork Slugga Boyz
Recently Completed: Ork Warbugies
Next Up: Ork Lootas & Moar Boyz!
In Da Fewchur: Ork Dakka Jet? Battle Wagon? Nobz Squad?
Updated: 13-Aug-18
http://www.dicedevils.com
#349
greggles
greggles
    Frantik
  • 2,074 posts
Thank you Grimdreg!  I was happy with the face paint.  Came out pretty good for just some blue pigment!
#350
Boss Ardnutz
Boss Ardnutz
  • 635 posts
Thanks for the pigment tips! Particularly about fixing, that's always been a concern for me since I like to vanish my models fairly heavily to reduce damage from playing. Sounds like I could get away with fixer or alcohol, followed by a careful coat of airbrush varnish?
#351
  • 2,506 posts
Would advise a little bit of caution - I have some 'sci-fi' metallic pigments I got from MIG which include a fantastic steel one, wipe it over something worn and it looks superb.
DO NOT GO ANYWHERE NEAR IT WITH VARNISH AFTER YOU'VE APPLIED IT - IT GOES BRIGHT BLUE.
Suggest trying it on something disposable (or, at least re-primable) to make sure that the colour doesn't do anything wierd :bang
#352
greggles
greggles
    Frantik
  • 2,074 posts
Agree with Badfang. Always test first! As I said earlier, I don't generally bother fixing the pigments, as they are beyond a joke to reapply (takes mere seconds).  It's literary like applying makeup to a model.
#353
greggles
greggles
    Frantik
  • 2,074 posts
Got a ton done on the looted knight. Just metal chips and powders to go!
Spoiler
  • Lexington, DocNuK, Orkimedez and 3 others like this
#354
greggles
greggles
    Frantik
  • 2,074 posts
Finally finished Big Blue!
Spoiler
  • Lexington, kreell, Badfang Brassaxe and 2 others like this
#355
greggles
greggles
    Frantik
  • 2,074 posts
Part 2
Spoiler
  • Lexington, Orkimedez, Badfang Brassaxe and 2 others like this
#356
  • 2,506 posts
Nice job - particularly liking the cracked white paint effect and the lumpy looking rust :thumbs
Off to throw some more pigments at my dredd now :lol
#357
greggles
greggles
    Frantik
  • 2,074 posts
Thank you thank you! Yesss moar pigments!
#358
    Dethkopta Pilot
  • 1,730 posts
  • Army Name:Freebootaz
Looks good, kinda feels like it needs checks and dags or something to give it more contrast. Impressive build all the same!
The Orks are the pinnacle of creation. For them, the great struggle is won. They have evolved a society which knows no stress or angst.
Who are we to judge them? We panzee who have failed, or the Humans, on the road to ruin in their turn.
And why? Because we sought answers to questions that an Ork wouldn't even bother to ask.
We see a culture that is strong and despise it as crude.
#359
greggles
greggles
    Frantik
  • 2,074 posts
I tested a set of white checks on the shoulder, didn't like how it turned out, so scrapped the idea.  I could always redo a shoulder later and try doing the checks earlier in the process so it chips naturally with the rest of the paint.  There is a slew of checks on the gattling gun, but not very obvious, def could use more!!!!  Appreciate the feedback, helps me become a better painter!
#360
greggles
greggles
    Frantik
  • 2,074 posts
Off to Nova Open! Stop by and say hi if you see me!
  • Badfang Brassaxe, Giganotosaurus and Tomas Azmond like this
Also tagged with one or more of these keywords: orks, trustinrust, warhammer 40k, deathskulls, badmoonz, walkers, painting
