Contemptor Dreadnought vs Morkanaut
39 replies to this topic
  • 419 posts
Kans are also not nearly tough enough and if they lose a model, they get murdered by a failed morale roll...
You have to baby sit with with warboss or nobz... waste of poonts there as well... Honestly I never tell my opponent about them having to take moral tests. XD
  • 1,026 posts
Thats cold...
Shabbadoo
Shabbadoo
  • 1,874 posts
  • Army Name:Bad Moons(Waaagh! Skargrim)
Morale isn't really much of a factor, but when a check is failed it just annihilates this unit.  They could have written Morale failure as sustaining additional Mortal Wounds, meaning it would remove whole models from 1 wound chum units (as desired/intended), but merely serve to "weaken the resolve" of tougher multiple wound units (as seems appropriate). At this point, they could tweak units instead to lose one wound rather than one model per point of failure. Better to address the core mechanic though.
Orkimedez
Orkimedez
  • 179 posts
  • Army Name:Waagh
Guys...we are talking about gretchings driving robots. For once, cowardice is reflected in the rules.
I understand and support that the kans are badly costed (just accounting the moral here should reduce their price). However, I think moral should be their weakest point.
  • Blakkreaper likes this
  • 4,877 posts
*Gretchin.
It's already plural. Come on people. Now, back to whatever crap you guys are talking about.
  • 419 posts
I'm disappointed. I was expecting an essay.
  • Badfang Brassaxe and Giganotosaurus like this
  • 277 posts
There are times when verbosity is wasted Skumdreg.  Sometimes less is more.  :yes
  • 4,877 posts
I realise it could come across as nasty, especially as Orkimedes is likely speaking English as a second language, but it always triggers me. No least because this error is in this month's flippin' White Dwarf.
As for 40k and Dim essays, working on the last dozen I'll likely ever write. No longer worth the effort.
  • Skumdreg likes this
  • 1,861 posts
Gretchings - the new max copyright grots :?
  • 4,877 posts
Don't start. ;)
Gitkilla
Gitkilla
  • 200 posts
  • Army Name:Death Skulls
Was it ever worth to write essays? I thought the only language they speak is money.
Metal elitist & into game/level design.
  • 4,877 posts
Considering the effort they expend, depending on your view "caring now" or "pretending to care", I'd say at the very least those who openly criticised GW had a direct impact. It's amazing what some people will put up with if nobody says "something's wrong here". Criticism is important. I did my bit, maybe it helped. My goal was never to get through to GW. I never felt I should have to explain to a company charging money for every single thing they do to be told they should be doing it significantly better, to you know, maybe come close to matching the price they're selling it at. I never thought GW needed a bunch of free advisers to tell them where they went wrong, which is pretty ironic considering that's their primary mode of fixing things at this point. My opinion on the importance of criticism hasn't changed, I've just finally accepted the futility of it. GW makes shit games, charges a fortune for it, and people who just need an excuse to push expensive plastic around give them money. The cycle repeats.
I wrote essays because I used to care about this game. I don't anymore. It's pretty obvious that writing quality is going to remain the one thing GW wont hire the talent for. To be fair, the talent probably wouldn't touch them with a ten foot barge pole, but then that's their fault anyway.
  • 1,128 posts
Regarding the Kans. the last few times I ran kans there were either solo's or units of 2. Haven't had any of them run off on me. I kinda like dreads better for the stats.
  • 4,877 posts
The main thing I don't understand with Kanz is the pricing of the Grotzooka. That thing is definitely overpriced for what it does.
(There we go, back on topic for you)
  • 1,128 posts
I've never done a comparison of the points. Kanz do cost a bit too much I guess. Mine come in at a flat 60 points.  The ones I use the most.
If the drop a little in points I'd be fine with that.
Orkimedez
Orkimedez
  • 179 posts
  • Army Name:Waagh
I stand corrected. Let's move on.
  • Dim_Reapa likes this
Shabbadoo
Shabbadoo
  • 1,874 posts
Already covered in detail in post #19. ;)
Well of course not.  If its buddy is taken out, the second Kan of a 2-Kan unit will only run on a 6, unless some sort of Morale modification effect is affecting it.
Sure, but perhaps sticking a Gretchin in an armored shell of awesomeness would give them anything but a false sense of security? One would think that they just might be a bit more ballsy than a naked gretchin just walking about. Not many units with 60-ish point models that can lose one model per point failed on the Morale check have a Ld of 6. The core rules literally work against any unit with a high point cost and low Morale. The only way to really deal with fixing that is with a Morale boost, points decrease, or a special rule (if one does not want to alter the core rules). Orks in Deffdreads get a Ld bump. Why not Gretchin? I am of the opinion that ALL units in the Ork army should have Mob Rule, not just Orks, because Gretchin have a mob mentality too. For small units like Killa Kans, Mob Rule does nothing for them on their own, but if they are near another larger unit, that would embolden them (and rightly so).
  • 1,128 posts
Fair enough. I have 6 for my unit but never like the idea of fielding all of them in a single unit because of points and I did manage to put 4 r 5 of them in a single unit once but 3 of them were destroyed, of something like that. maybe it was 4 in the unit and 2 were destroyed. I can't remember. too many points to have so much die on turn one.
Dreads have been slightly better depending on who i'm playing against.
I've set my Orks aside for a while now and probable won't look at them for a few months. When we start getting codex rumors and leaks.
I've had very little free time to play so fart his year. so I'm not up on my rules/stats/points ect.
  • 1,861 posts
 so fart his year
Priceless :lol
  • warhead01 and Giganotosaurus like this
  • 277 posts
"...so fart his year." Orks will be Orks.  ;)
  • warhead01 and Skumdreg like this
