What size for Tube A to fit in to Tube B
Plasticcard
LEGO116
LEGO116
  • 3 posts
So im trying to make Plasticcard guns and what not, im wondering what is the size I need for Tube A to fit in to Tube B, If tube B (the one im putting into) is 5mm should tube A be 4MM, half as wide so 2.5mm or, should A be 0.1mm less wide?
  • 2,545 posts
Tubes have inside diameters and outside diameters, for tube A to fit into tube B then the outside diameter of tube A cannot be greater than the inside diameter of tube B. Unless you know the 'wall thickness' (aluminium tube has a thinner wall than plastic for example) then you're going to have to guess or ask the seller.
FlamingDeth
FlamingDeth
  • 273 posts
You can also cheat by drilling the hole wider in the outside tube with a pin vice, which for guns I would recommend anyways, as the walls on styrene tubes are typically pretty thick. An alternative is using some kind of brass/copper/aluminum tube for the outside, as the walls on those are typically thinner.
  • 2,719 posts
These are the smallest tubes I have.
This should be more to the left towards the zero line
C50-AAF8-F-885-D-4-BB7-A831-F8125-DB65-EFE79951-E-1163-4624-BD6-A-F628140455-D6.
Call them 4 & 6cm?
0706-D9-E7-1288-4406-8-B99-3-A37-A25-EF5
This would be vehicle grade caliber. Maybe based on those proportions go at least 1 size between tubes.
Another technique you can is punching a pattern of staggered holes in thin sheet, then using hot water bend it into an arc to form a heat shield around the barrel.
For small arms and pistols remember that the body of sluggaz & shootaz is boxy and rectangular cube so you only really need that and small tubing for the barrel.
  • 2,545 posts
Call them 4 & 6cm?
I think that should probs be 4 & 6 mm :biggrin
Was going to say that all our tubing is still in imperial (at least, the metal ones are) - plastic tubing I used to get from model shops and try the tubing sizes by pulling them out of the rack, sliding them in and out of each other and seeing for myself.
  • 2,719 posts
Either way. All's I knows is that it ain't inches!
