Dood515's Vehicle Log!
34 replies to this topic
dood515
dood515
  • 302 posts
  • Gender:Not Telling
  • Army Name:Kogbasha's Trakkboyz
After a while away from the hobby, I've been feelin' orky, and by that I've been feeling Mekky!
I'm 2 rulebooks behind now so only time will tell if I bother to start playing again ... but here's the start of the mekboss' new tank!
Started off with some old chimera tracks (from one of the old part-metal hellhounds), managed to pry 'em open and double 'em up for that fatboy look.
Tore the horrible lumps off the sides and bolted on some metal plates.
It's my first time makin' me own tracks so hopefully they'll look alright with a little bit of detail added to each one ...
Here's the basic mockup of the shape::::::::
My only issue for now is how to mount the turret ... I've got a box of beakie bits on the way, including a number of razorback back hatches, I'd strike a guess they're the same size as the BW turret?
Comments and moanins' welcome.
One of the many reasons why orks are more fun to play; Bosspoles:
"Roight ladz!, Barry's dead, an' if you don't kill dat fing Steve's dead too, alroight!!?"
QUOTE (Oddballz @ Dec 8 2009, 11:02 AM) *
I like my armies to have proppa guns, tracks and wheels, and not gribbly appendages with veins and orifices.
I seem to have started a blog: http://therustywartr...blogspot.co.uk/
the 1st pip
the 1st pip
  • 391 posts
  • Gender:Female
  • Army Name:Gorgutz Blud Axe Freebooterz
You could do with either less gap between the hull and turret, or bulk the gap out with something.
Otherwise a perfectly fine start for an old model.  Just go where your imagination takes you!
My current Ork Deffwing project Deffwing
My Ork Album Blood Axes
dood515
dood515
  • 302 posts
So I completed tread set #1 !
Quite chuffed, doesn't look half bad to me ... or it won't when it's painted.
@the 1st pip - thanks, like I said in the first post, the turret is just in a mockup. I'm waiting on a box o' bits to fit it to the hull. I plan on bulking up where it fits, or slotting it lower, in the hull somehow :)
    Looted Russ Gunner
  • 1,985 posts
Personally I quite like the look of the turret, it looks vaguely like an orky version of a WW2 Bishop - Centaur tank chassis with a turreted 25pdr field gun bodged on top  http://www.google.co...iw=1029&bih=680
dood515
dood515
  • 302 posts
Little bit late for startin' the other tracks so I thought I'd get some plating done. Whilst I'm making my own tracks, why not give rivetting a proper go too?
Not sure which picture would come out best:
DarkTalon
DarkTalon
  • 31 posts
  • Army Name:Waaagh Grabnutz
Love the plates! might i suggest adding some rivets to the tracks as well?
You can teach a robot how to dance, but you can't teach a pair of shorts how to pants.
dood515
dood515
  • 302 posts
@DarkTalon - Thanks! After rivetting the plates the tracks did look a little bare didn't they?
Took a rivet gun to the tracks and replaced the plates on the side with some of my own, which I think look more consistent and better overall :)
Now to start on the other trackks ....
DarkTalon
DarkTalon
  • 31 posts
Now that's proppa!  Also, your meks must enjoy playing with the rivet gun, those plates shouldn't get knocked off too easy! :)
dood515
dood515
  • 302 posts
Progress! Rather than working on the other tracks like I should have done, I did something more exciting and built up the hull for a big shoota mount.
 .... aaaand bits!
Notable haul:
- 11 razorback top hatches
- vindicator plow construct ( I think it's complete! )
- vindicator cannon with cannon surround + front armour plate to fit it to (plus 2 thirds of another cannon)
- several rhino top hatch doors
- several rhino and landraider style doors
- 8 or so tank hatches
- missiles
- worky panels
@DarkTalon - Thanks :)
Might get round to them damn tracks now ...
  • urluck likes this
Sprocket Ratchetswinga
  • 32 posts
  • Army Name:Sprocket's Junkers
Put some glyphs on that, like the symbols and such. Nice and ramshackled tho! Add that screen on top with like a grot of something working on a firing pattern or something. Thats a prime piece and could add a little story
Edited: I cant word
the 1st pip
the 1st pip
  • 391 posts
  • Gender:Female
I do like the gun mount, and the tracks look very nice.
dood515
dood515
  • 302 posts
@the 1st pip - Cheers!
Got the other tracks done ... not as good as the first set but they'll have to do as I ain't startin' again:
I added a bit more to the hull too, to tie all the plating together and make it look less like bits were just tacked ontop.
Probably the most plasticard work I've done and I'm pretty happy with it so far ...
Comments and moanin' welcome!
DarkTalon
DarkTalon
  • 31 posts
Just remember, paint does ALOT to a model as well, don't fret small differences! :)
Skullwhompa
Skullwhompa
    Hair Squig
  • 69 posts
  • Army Name:Waaagh! Skullwhompa
Looks really good so far, and I totally intend to loot your track idea.
Honor is bulletproof.
Alienerd
Alienerd
    Wartrukk Gunner
  • 1,678 posts
  • Army Name:Rebel Grotz
You can still tell its a chimera at the base but you're really making it your own :thumbs
I like the little big shoota mount at the front, and the extra detailing on the tracks really adds a lot to them.
How many kans can a killa kan kill if a killa kan can kill kans?
Scoutfox
Scoutfox
  • 317 posts
  • Army Name:Da Wamp Gataz
I like the direction your build is taking. Where did you get all those tanks bits? That is quite the haul.
For not really doing plasticard work you are off to a fine start. Try and ding up the edges a bit first and add scratches and bullet holes before you add them to the wagon. Just take a sharp scalpel and cut a but off the edges of each piece, sometimes knocking a corner off so they aren't all perfect squares and rectangles. Then take a file and scrap a hard edge across the plates. For bullet holes I just dig my file through the plasticard in a twisting motion, and scrap up the entrance.
the 1st pip
the 1st pip
  • 391 posts
  • Gender:Female
What Alienerd said!
There is no moaning, it looks really good.  It looks like it was knocked together, but still retains the shape of a Chimera.
Good job!
dood515
dood515
  • 302 posts
Update!
@Sprocket Ratchetswinga - Thanks! Not quite following all of what you said but I tried include a few little glyphs as I don't have any of the normal square ones left and didn't feel like making any ... I might make a 'mast' though with a nice big glyph on it, if I feel like it.
@DarkTalon - I hope so! Haven't painted in a while and might try something a little different to my usual techniques this time.
@Skullwhompa - Thanks alot! The track idea isn't one of mine, as some of the veterens here will most likely happily tell you, it's been done for a while, I looted the idea from lookin' through DA OILA'z BLOOPRINTZ
@Alienerd - Thanks! :) I'm quite proud of the surround for the BS and glad I added the track details too.
@Scoutfox - Thankyou! I bought two 'job lots' off ebay for about 12 quid each, that one, and another with leman russ barrels and basilisk barrels and all sorts ... which I'm waiting on so I can complete this build. I have dinged up the plates it just doesn't show up well with my inferior camera skills.
What people want to see ... pictures! ::::
The structure of the top / back. Razorback top hatch with a COD pole for support and that chimera/basilisk plate before more platicard some werky bitz.
Also, finished plating up the other trackside.
so all that's left is the turret which will likely be the battlewagon one with with a russ or similar turret for me BOOMgun.
Comments and whatnots welcome!
Big_Mek_Boomsprocket
  • 135 posts
  • Army Name:Big Mek Boomsprocket's redpants reaverz
I like it! You gonna pt anything in the hole on the back, or make it a sort of cavern for your troops to ride in?
Orks is made fer fightin and gettin shot up before dey gets ter klose kombat... :crybaby
-Big Mek Boomsprocket
Fight the prices, sign this petition: https://www.change.o...tures/u/8516714
Alienerd
Alienerd
    Wartrukk Gunner
  • 1,678 posts
  • dood515 likes this
